查看: 6980|回復: 13
[廠商公告] E20引擎內部清洗劑
發表於 2013-8-14 23:59:16 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 小霖 於 2014-3-30 14:45 編輯
VOLTRONIC E20 引擎內部清洗劑
http://www.voltronic-germany.com/e20-engine-flush.html
特性:
1.清除刮油環及汽缸套的積碳
2.清除微粒金屬.油泥及油垢
3.恢復引擎效能回復燃燒效率
4.含有耐腐蝕抑制劑,可中和引擎中的酸性有害物質
5.不傷金屬及非金屬物質
6.不會傷橡膠原件(NBR/SNBR/AEM/ACM/FKM...)⋯⋯
7.能活化油封降低滲油與汽門油封硬化所造成的白煙現象
8.可增加金屬結構韌性,如波司/轉軸/活塞環...等
9.符合歐盟六期環保標準
使用E20+VOLTRONIC保養套餐組試試,會有意想不到的驚喜喔
使用方式:
更換機油前將E20加入引擎內(5公升以內機油對應一瓶E20~ELANTRA整瓶全倒)
發動引擎運轉15~20分鐘(偶而提高轉速~建議單次不超過10秒&3000rpm)
也可在到達保養廠前20分鐘先加入引擎(正常行駛,轉速不要超過2500rpm)
到保養廠後即可洩掉舊機油,更換機油濾芯並倒入新機油
每次更換機油或10000km使用一次
汽油.柴油.CNG引擎均適用
VOLTRONIC ® E20 Engine Flush is advanced internal engine cleaner. Formulated with extremely low-ash material, comply to EURO-VI norm. Remove harmful deposit such as carbon deposit on piston and piston ring crapper, oil sludge, dirt aggregate and breakdown particles. With corrosion inhibitor for neutralizing acidity in the engine. Improve engine performance by restoring engine compression up to 99%. Does not contain aggresive cleaning material, friendly to seal material such as silicone, NBR, SNBR, AEM, ACM and FKM.
  • Features
    Remove harmful deposit such as carbon deposit on piston and piston ring crapper where caused of premature wear.
    • Improve engine performance, restore engine compression up to 99%, restore power, restore fuel economy and reduce emission.
    • Remove oil sludge, dirt aggregate and breakdown particles
    • prevent engine from premature wear, prolong engine life.
    Proven ground test 200,000 km mileage after facing oil sludge problem
    • Does not contain aggresive cleaning material, friendly to seal material such as silicone, NBR, SNBR, AEM, ACM and FKM.
    • Formulated with corrosion inhibitor for neutralizing acidity.
    • Clean hydraulic tappet, reduce tappet noise.
    Application
    Gasoline, diesel, CNG and hybrid engine, both with turbocharged or without.
    Usage direction
    1 bottle (250/300 ml) treat up to 5 litres motor oil. Fill into engine oil prior oil change interval. Run engine and give throttle intermittently for approx. 20 minutes. Drain, replace the motor oil and oil filter.
JSR + 10 + 100 + 5 給個讚!
發表於 2013-8-15 07:14:25 | 只看該作者
小霖大這產品多久用一次.比較好呢ˊ?還是跟保養ㄧ起使用
這次用3500套餐小小心得.未用套餐前冷車啟動.有打油空轉的感覺.那是超跑聲嗎.
現在已改善了.冷車引擎安靜.剛換套餐組.覺得不太適應.有其是洄油滑行.不好用.開了1千多後.低.中.在加速.高速.
順暢.我太座說安靜多了.
這支油的特性就是如此,而且還越開越有勁不衰退,換第2次之後就會更明顯  發表於 2013-8-15 12:33
 樓主| 發表於 2013-8-15 11:21:53 | 只看該作者
伊亞斯 發表於 2013-8-15 07:14
這次用3500套餐小小心得.未用套餐前冷車啟動.有打 ...
看使用的潤滑油品及保養週期還有里程數而定
 樓主| 發表於 2013-8-15 11:26:06 | 只看該作者
我是用VOLTRONIC 3500套餐組,10000km保養一次(約2~3個月),每次都洗
發表於 2013-8-15 12:00:26 | 只看該作者
發表於 2013-8-15 20:03:41 | 只看該作者
本帖最後由 aaron 於 2013-12-30 20:14 編輯
偶已經受受 新x路 [原廠] 了....
為了下面幾個問題...一直都沒有自備油品......
[方向機] 異音....       不是說 "沒聽到"... 就是說 "正常"!!
[排擋電磁閥] 聲音過大....   也說是 "正常"!!
發不動....           連更新電腦都懶了!!
恁娘咧...有什麼是 "不正常" ?
其他 "哩哩扣扣" 的問題....偶是暫且不計較.....帳都還沒算呢.....
下次 25000km保養~ 準備要換保養廠...也要使用這組套餐啦!
人情的關係... 偶很給人家留面子了!  發表於 2013-8-15 20:08
你還忍這麼久才換保養場喔...@@ 早就該換了吧  發表於 2013-8-15 20:05
發表於 2013-12-30 18:43:21 | 只看該作者
小霖大大這瓶如何使用阿
 樓主| 發表於 2013-12-30 19:53:05 | 只看該作者
本帖最後由 小霖 於 2014-2-5 01:25 編輯
小K 發表於 2013-12-30 18:43
小霖大大這瓶如何使用阿
使用方式:
洩掉舊機油,更換機油濾芯並倒入新機油
每次更換機油或10000km使用一次
汽油.柴油.CNG引擎均適用
本以為加入進去只能空等他20分鐘不能行駛~~如能這樣就很方便,因為怕技師也沒耐心在那空等...$$?  發表於 2015-3-15 11:48
霖大,E20也可自己先在地下室打開機油蓋加入,引擎轉速看您說明別超過2500轉,開到保養廠就剛好給技師洩油換新油,所以在行駛間別超過轉速是ok的囉?  發表於 2015-3-15 11:47
發表於 2014-4-29 13:12:09 | 只看該作者
E20價格是多少呢?!
昨天到竹北金弘笙沒看到,所以就少買了~~ 新竹還有其他點可以購買嗎?!
GMT+8, 2026-7-22 04:48 , Processed in 0.079695 second(s), 22 queries , Gzip On.
